Port starter replaced cranks no start
- Greenhornchris
- Vessel Info: 1989 carver 3207
- Has thanked: 4 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Port starter replaced cranks no start
If I’m wrong on this, I’m sure someone more knowledgeable will correct me.
There's a number of things that could be the problem here;
- could be an electrical issue like a bad battery or wiring
- could be an ignition issue, check your ignition components, when was the last time she had an ignition tune-up? Pull off the distributor cap and check the contacts and rotor tip, if they're corroded or you see any cracks in the cap, replace them. Is she producing a spark?
- could be fuel related, not getting fuel, carb issue, bad filter, water in fuel, old fuel, fuel pump failed
- might have a bad exhaust manifold and water is getting into the cylinders, this could cause slow cranking and could stall the engine
You'll need to go back to the basics and determine which system is the culprit; fuel delivery or poor/no ignition. Do a proper battery test to eliminate the battery as the problem. Test for spark with a proper spark tester designed for marine use otherwise you'll be putting yourself in a dangerous situation.
How did she stall, did she suddenly stop with no warning or did she cough and puff, slowly losing rpm before finally shutting down?
- waybomb
- CYO Moderator
- Been thanked: 490 times
- Greenhornchris
- Greenhornchris
- Greenhornchris
- waybomb
- CYO Moderator
Forget the fact that it's oil filled. That is not an issue. You will not get much of a spark if you use a resistor coil with an inline resistor!
Look up "ignition resistor" on any automotive parts site so you know what you are looking for
