396 2001 Carver Transom shower
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 56 times
- Been thanked: 32 times
When winterizing my boat for the first time last year I pulled out the transom shower head and expected to turn it on and and flush it with the non toxic antifreeze from my water tank, nothing came out. During my one season of ownership I never used it.
Is there anyway to access the supply lines from behind without having to removing all the caulking from the valve enclosure on the outside of the transom?
Thank you anyone.
- Been thanked: 654 times
Re: 396 2001 Carver Transom shower
- paulr
- Has thanked: 602 times
- Been thanked: 1311 times
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
If you look inside the aft stateroom closet on the starboard side (see pic below) and look in the back of it you should find a panel that can be removed which will give you access to the hoses/connections. I have an old photo I took of the connections when I replaced mine - it's not great but I'll post it below too.
The shower faucet assembly was leaking on ours so I ended up replacing the faucet assembly and all fittings. I found one online that fit the plastic enclosure which was nice since I didn't have to enlarge/reconfigure the opening for the external enclosure.
If you have any questions just let me know! Good luck!!
Kyle
2002 Carver 396
- paulr
My fear last year was that I couldn't be sure it was properly winterized.
This year was rough for maintenance. Rebuilt both Vac pumps, replaced FWD air cond., and the ice maker.
- paulr
I have worked with other push to connect fittings before.
Is there any trick to get this type apart? They don't seem to have the part that you push in to release them.
- KyleR
2002 Carver 396
Kyle
2002 Carver 396
- paulr
Hopefully, the only thing I have to replace is the shower handle and hose but now I am prepared for everything.
Thank you.
Users browsing this forum: Google [Bot], KyleR and 71 guests
