Loss of RPM’s on both engines at wot
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
- Been thanked: 654 times
Re: Loss of RPM’s on both engines at wot
- Merkinbrumsky
g36 wrote:Source of the post Did you run it after the marina did plugs ,timing etc last year and verify it was "tip top"? Or was it put away after the work for the season?. Can you tell if your trim tabs are actually affecting the boat when your adjusting them?
Yes, I’ve run it a bunch since they tuned it. It was running good up until sometime this summer. I always open it up in the spring to make sure everything is good and it ran great. Last time I had it up on plane was probably late July and it was running normal then. Since then I’ve been just cruising at trawler speeds. Tabs are working for sure. Marina is suggesting the hull is fouled by zebra mussels but I put the mask on and checked yesterday. Hull is clear except for a small bit of algae along the waterline near the transom. Nothing significant. They are going to run some diagnostics on the engines but the season will likely be in the books by then.
- Been thanked: 1113 times
- Has thanked: 602 times
- Been thanked: 1311 times
Do you have a sync gage on the dash and if so how does it look as you throttle up, does it favor one side more than the other ?
- Merkinbrumsky
bud37 wrote:Source of the post One thing to remember is that one engine can take the other one down ( hold it back from accelerating ) as the props / rpm will be roughly the same on both sides.
I do have a sync. Tough to tell as the the throttle positions have been off slightly as long as I have owned the boat. The stbd side always ends up further ahead to achieve the same rpms but when both are pushed to the limit the port side won’t travel all the way fwd ( about 90% of the way) but was achieving wot rpm’s. I assumed it was a cable adjustment issue and that job was on the list.
At least this will cross something off the list. Check and clean flame arresters while you are there.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Merkinbrumsky
Cooler wrote:Source of the post Flame arrestors are easy to clean, but a lot of people just ignore the fact they need maintenance. Not only do dirty arrestors choke off air to the carbs, they can be a real fire danger. I would bet it is fuel related. Did you top off with ethanol gas last year? Good luck!er
It would be non-ethanol from the marina fuel dock. I will check and clean the arrestors as well next trip as well as change the fuel filters
and confirm both throttle plates are open all the way. Engines are getting up there in hours approaching 1300.
Can you post engine serial numbers?
