lake water leak
- Ken McDonald
- Vessel Info: 1987 3807 Aft Cabin
lake water leak
I had the water tested to determine if it's from the holding tanks or lake water and it's definitely lake water. I checked for leaks at all 7 seacocks and everything is dry. The water from the stuffing box (very little) goes into the aft bilge.
The boat comes out of the Water in a few weeks and I'm hoping to figure out where the leak is coming from so that I can fix it on the hard.
Any thoughts of how I can diagnose this problem or where it may be coming from would be greatly appreciated.
Re: lake water leak
Do you have the original shower sumps that look like open Tupperware containers? The forward one in mine is located right in front of the forward water tank in the floor beside the galley. If the shower sump isn't working and you have the original sump, it could be overflowing into the bilge. The shower drains into it but so does the condensate from the forward AC unit. If you have a raw water leak at the front AC unit, it could be draining into the sump or the bilge.
Also check and ensure that your engines and generator including the exhaust aren't leaking raw water either running or not.
- Ken McDonald
Re: lake water leak
Maybe I should dam the water coming from the stuffing box in the engine area see if the forward bilage remains dry?
I checked for leaks in the engine cooling system and everything looks good. The forward A/C was removed before I bought the boat and the forward shower pump was replaced with a much better and more efficent one then the original.
Thank you for your insightful comments.
Ken
Re: lake water leak
- Been thanked: 1113 times
Re: lake water leak
Ken McDonald wrote:Source of the post
... Maybe I should dam the water coming from the stuffing box in the engine area see if the forward bilage remains dry? ...
You could also take something like a milk jug and cut the top off, then position right below the stuffing box and hold in place with a couple small two-sided adhesive pads underneath. They'll eventually overflow, but should give you plenty of time to further diagnose. (and you could periodically vacuum them out if you need more time).
Users browsing this forum: No registered users and 43 guests
