Steering Wheel
lz33w7
Vessel Info: 1987 Carver Mariner 3297
Steering Wheel
Postby lz33w7 » October 10th, 2024, 4:12 pm
Hello friends,
New to boats and just purchased an 1987 Mariner 3297. Can the steering wheels in these boats be replaced?
Kindly,
v/r,
Stephen
Re: Steering Wheel
Postby Midnightsun » October 10th, 2024, 5:54 pm
Yes easily. You need to pull yours off to see the shaft used but most likely it is a tapered shaft and keyway with a nut holding it in place. Some older units may have a splined shaft.
Here is a link to eBay, tons for sale there and where I have always found mine over the years.
https://www.ebay.com/sch/i.html?_from=R ... s&_sacat=0
lz33w7
Re: Steering Wheel
Postby lz33w7 » October 14th, 2024, 6:25 am
Thank you, my friend. So these are the measurements and details on the wheel I purchased….
Boat Steering Wheel3 Spoke Thermo PlasticSoft grip wheel easy to hold and use3/4' Morse taper340mm DiameterNon magnetic so will not affect compassesAlloy hub with tapered boreSoft Grip sports wheelColour: White
Do you think this will work?
Kindly,
v/r,
Stephen
Re: Steering Wheel
Postby Viper » October 14th, 2024, 10:10 am
You'll have to take measurements of what you currently have. The bore type and diameter is important for mounting but the diameter of the wheel is important too.
lz33w7
Re: Steering Wheel
Postby lz33w7 » November 20th, 2024, 12:26 pm
New Steering wheel installed:
Re: Steering Wheel
Postby Viper » November 20th, 2024, 8:38 pm
NICE :down:
Users browsing this forum: No registered users and 61 guests
