Black tank vent filter.
Notsooowicked
Vessel Info: 2000 Carver 396
Has thanked: 6 times
Postby Notsooowicked » November 28th, 2024, 1:56 am
Hi All,
I recently bought a 2000 396 and have been working on getting her back in order after a few years of neglect. Can anyone please tell me where the black tank vent filter for the forward head is located and how to access it? My newly established pump out service had been only pumping one tank…sadly, the wrong one, so it backed up in the vent.
The vent seems to be clear now, but it think the filter has been fouled. I would like to remove it, bridge the line, flush the vent, and install a replacement, but I can’t find it.
There is a wood platform on top of the forward black tank, and I fear underneath is where the filter may be found, but I am not sure because the origins of all the lines seem to be visible. So before I start what seems a difficult process of removing that platform, I would love for someone to advise.
Thanks so much.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 137 times
Re: Black tank vent filter.
Postby KyleR » November 28th, 2024, 8:46 am
We're away from the boat visiting family for Thanksgiving but when we get back this weekend I'll post pics of where ours "used" to be. After a lot of research (google search for Head Mistress Peggy Hall) I came to the conclusion that a well maintained blackwater tank doesn't need this filter, and just causes extra work and expense.
Also, search my profile (and other 396 owners specifically) for posts and you'll find a lot of 396 info I've posted over the past couple of years regarding issues I've run across. We're full-time liveaboards and we've seen a lot! Welcome to the forum and good luck!!
Kyle
MV Verity
2002 Carver 396
Carverlvr2
1979 Searay Sundancer 260
Been thanked: 25 times
Postby Carverlvr2 » November 28th, 2024, 10:15 am
Sounds like KyleR will get you what you need. I have a 366 and assume it’s similar in a few areas. My fwd vent filter is easily accessed in the storage area under the settee/galley. The Va I flush and system water pump are in there and the filter is right above the VF mounted on the wall. Maybe yours is the same?
Notsooowicked
Postby Notsooowicked » November 28th, 2024, 11:23 am
Thank you both so much!!
Been thanked: 1310 times
Postby bud37 » November 29th, 2024, 9:15 am
Good to see the larger vent size......It is much easier to deal with tank odor with the large vent size for better air flow, as opposed to the small hose.
paulr
Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
Has thanked: 54 times
Been thanked: 32 times
Postby paulr » November 29th, 2024, 10:33 am
I have a 2001 396 Carver. Neither of the black tanks have a filter and never did. What the filter does for you is to neutralize the odor exhausting from the vent when you flush or when the boat may be rocking in the marina.
When living on the boat in the summer in NJ we pump the boat each 5 to 7 days so the odor doesn't present a problem. If it gets really hot in August it will smell
begin to smell. If that occurs add some black tank deodorizer and that will control the odor until you can pump out.
Regarding how the filter became fouled, I had to replace the "Tank Watch 4 " sensor on the black tank and the Gauge mounted in the medicine cabinet in the head. I did this in the aft tank. The forward tank sensor and gauge is still working but I know it will fail as I know 2 other 396 owners in my marina that had the same problem. When the light turn red, stop using and pump out.
KyleR
2002 Carver 396
Postby KyleR » November 30th, 2024, 11:09 am
Here's a pic to show where our filter used to be (circled in yellow). I replaced it with a length of PVC when I removed the filter element.
There is also another pic to show where the vent line leading from the blackwater tank to the filter is located. If your filter is not in the same location at least you can trace out that line and see if you have a filter. Let me know if I can help in any way.
Kyle
MV Verity
2002 Carver 396
Notsooowicked
Postby Notsooowicked » November 30th, 2024, 12:24 pm
This is awesome, thank you so much!!!
