Rudder shaft repair
- Blu3
- Vessel Info: 1983 carver mariner 28'
- Has thanked: 4 times
Rudder shaft repair
I am trying to prepare parts for a haul out.
I have a 1983 carver 28' mariner with a stuck rudder I believe the bearing or sleeve was damaged when trying to remove the prop laborer said he heard a crack. He used a piece of wood against the rudder to keep the prop from spinning while trying to loosen the prop castle nut.
I found a few parts but I am not sure exactly what my boat needs and before I haul out I want to have parts on hand to avoid wasted lay day fees.
Any help would be appreciated here is what I found so far but not sure what my boat needs.
https://www.greatlakesskipper.com/tides ... 7-1-4-inch
https://www.greatlakesskipper.com/tides ... uis-yachts
https://www.greatlakesskipper.com/tides ... -4-id-pair
https://www.greatlakesskipper.com/tides ... 1-1-4-inch
Channel Islands CA
- Been thanked: 1113 times
Re: Rudder shaft repair
- Blu3
I've exposed the top of thee rudders and removed the battery box wood.
Loosened the support beam that spans the width of the rudders so I can get to it easily I will measure right now.
Channel Islands CA
Also interesting, that the last one you posted says in the title it's "Carver 1 1/4 Inch", but in the text and the diagrams show 1 3/4" measurement.
- Blu3
I talked to the yard today and they think those are for newer boats.
My rudder tubes have packing glands similar to the prop shafts.
So I'm thinking its just a sleeve that the rudder slides into.
Channel Islands CA
- Has thanked: 602 times
- Been thanked: 1311 times
https://www.stevestonmarine.com/Buck-Al ... YVfYAq-1wh
Before buying the tube, you really should inspect your current one first, it may be fine and what you really may need is to straighten is the rudder shaft instead or replace it. If the tube is still perfectly round, the problem may be the shaft, but finding out means a hall out first.
- Blu3
I have some direction now at least.
Will let you know how the haul out goes and try to take some pics.
Channel Islands CA
Users browsing this forum: No registered users and 68 guests
