Replacement props
thisismurph
Vessel Info: 1993 Santego twin 454 crusader engines
Replacement props
Postby thisismurph » December 26th, 2024, 5:41 pm
Hi
I'm looking to replace two damaged props on a 1993 340 Santego. 18 x 23 four blade 1 and 3/8 shaft Would love to find something used. Do I need to have the exact same prop or is there some wiggle room
Thanks!!
Has thanked: 603 times
Re: Replacement props
Postby bud37 » December 26th, 2024, 7:11 pm
Welcome to the forum.......
thisismurph wrote:Source of the post Do I need to have the exact same prop or is there some wiggle room
Thanks!!
This will really depend on how your boat was running before the damage......did it get on plane smoothly and relatively quickly without drama, what was your max (wot) rpm on plane. If you can lay that out , a good prop shop can help you make a qualified decision.
A small change in prop sizing may not have too much effect but if you are at one end of the range or the other for your boat as it is now ( loading etc ) it can make quite a difference to running and efficiency.
Alanna Mo Cree
Vessel Info: 2003 360 Sport Sedan
Twin 8.1Gi Volvo Penta FWC
Has thanked: 46 times
Been thanked: 70 times
Postby Alanna Mo Cree » December 27th, 2024, 12:51 pm
I had a damaged prop fixed on a previous boat. I hit a rock and tore a big chunk out of it. They were able to fix it up as good as new for pretty reasonable from what I remember. That was quite a few years ago.
Charlie & Jennifer
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
Postby Viper » December 27th, 2024, 9:28 pm
Welcome aboard. Ya I'd get them looked at by a prop machine shop first. A reputable shop won't charge you for assessing and giving you an estimate for repair.
MyPleasure
Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
Been thanked: 23 times
Postby MyPleasure » December 28th, 2024, 11:22 pm
For myself, I would want to know what max RPM is for the engines on your boat? Did the engines reach that RPM with the boat loaded up with fuel and water? A lot of boaters over prop their boats to get more speed at a lower RPM, but you’re actually putting more load on your engine with the oversized props.
We had a 36 Uniflite with 350 Crusaders, when we bought the boat, it would only run up to 3500 RPM, and get about 18 knots with zero vacuum, (some previous owner had installed vacuum gauges on both motors).The props were 18” X 22” 3 blade with 1 1/2” shafts. I got a set of 4 blade props from a prop shop in Anacortes that was going out of business, so I got a great deal on them.
I had a great conversation with a local prop shop, and we determined that we wanted to get the engines up to max 4200-4400RPM at WOT. They figured out that the best diameter and pitch with the 4 blade props would be 16” X 17”, which worked out perfect. The boat max RPM now was 4300 RPM, speed was now 26 knots, and I had 5” of vacuum at WOT.
While cruising at the same 8 knots, the RPM was about 200 more, but the engines had 10” of vacuum, and got better fuel mileage because the engines weren’t working so hard.
if you’re not getting full RPM out of an engine, even when fully loaded, then you’re working it too hard at any RPM.
Just my opinion of course
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Been thanked: 285 times
Postby buster53 » December 28th, 2024, 11:58 pm
Yep, take them to a good prop shop first. You’d be surprised at what they can do with damaged props.
Users browsing this forum: No registered users and 44 guests
