2006 Carver 36MY trim tab reservoir fill
- KPT
Thanks.
Carverlvr2
- Vessel Info: 2004 Carver 366, VP 8.1’s
1979 Searay Sundancer 260 - Location: Shelbyville, IL
- Been thanked: 25 times
Re: 2006 Carver 36MY trim tab reservoir fill
Make sure you're checking and filling the reservoir with the tabs fully retracted (up). If oil loss has happened within a short period of time, you should be looking for leaks. While at the pump, check all the lines, fitting, and pump for telltale signs. The most common leaks though are at the actuators on the tabs. Also check the condition of the fluid currently in the reservoir, it should be ruby red. If it's a creamy colour, the system ingested water and needs to be remedied to prevent pump damage.
