Drain Plug Location 1989 Santego
bbagin1969
Vessel Info: Carver 1989 34' Santego
Has thanked: 11 times
Postby bbagin1969 » April 18th, 2025, 7:25 pm
I hope this message finds you well. I recently acquired a 1989 34' Santego, and I’m in a bit of a bind. Unfortunately, the drain plug wasn’t removed over the winter, and I’m having difficulty locating it. I would greatly appreciate it if anyone could share a picture or diagram indicating its location. I’ve managed to remove a significant amount of water using a trash pump, but there’s still a concerning amount left in the bilge and below in the engine area. :help:
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: Drain Plug Location 1989 Santego
Postby ColRon » April 18th, 2025, 8:27 pm
I seriously doubt that there is a “drain plug” ( otherwise known as a garboard plug like you find on runabouts) on the 89 3467 Santego, as it’s approximately 38’ in LOA and is not a typically trailerable boat. I know on my 89 3867 Santego there isn’t one. I understand hating any standing water in the bilge. What I cannot pump out using the bilge pumps, I use a wet/dry vacuum to remove. In fact, I keep one stored on my Santego specifically for this purpose.
Ron
“Escape Plan”
Murray, KY
:usa:
ColRon
“Escape Plan”
Postby ColRon » April 18th, 2025, 8:31 pm
Oh and by the way, welcome aboard and congratulations on your new to you Santego! :beergood:
Ron
“Escape Plan”
Murray, KY
:usa:
Been thanked: 490 times
Postby waybomb » April 18th, 2025, 8:40 pm
Our 3697 has a plug in the bottom about a foot in from the transom.
Welcome aboard!
Postby Viper » April 18th, 2025, 10:28 pm
Welcome aboard. Hopefully a member with the same model will chime in.
Postby bud37 » April 19th, 2025, 8:22 am
Welcome....is the boat out of the water now ? if so just look underneath along the keel ....start at the stern/aft area.
bbagin1969
Postby bbagin1969 » April 19th, 2025, 10:59 am
Thanks for the replies. I am trying to figure out how to upload pictures to this thread.
Once I do, I'll submit them for suggestions.
bbagin1969
Postby bbagin1969 » April 19th, 2025, 11:00 am
Here is another one
Thanks again.
Postby bud37 » April 21st, 2025, 6:08 pm
bbagin1969 wrote:Source of the post Thanks for the replies. I am trying to figure out how to upload pictures to this thread.
That just looks like a transducer for depth....
Postby Viper » April 21st, 2025, 6:14 pm
Ya the first pic is a ducer.
