2000 Carver 506 - 6CTA Cummins - Oil Pressure Sensor
KuyaJunGarage
Vessel Info: 2000 Carver 506
Postby KuyaJunGarage » June 9th, 2025, 4:42 pm
Afternoon everyone
Hope everyone is enjoying the boating season
My oil pressure gauge (port) keeps jumping up and down which makes me think its the oil pressure sensor. I can't seem to find the part number in any of my manuals.
I tried calling Diesel Parts Direct and gave them my engine serial number but no luck.
Anyone know know where or how to get the part number?
Kuya
Has thanked: 597 times
Been thanked: 1281 times
Re: 2000 Carver 506 - 6CTA Cummins - Oil Pressure Sensor
Postby bud37 » June 9th, 2025, 5:20 pm
Heh there, can't help with the # for you ,maybe you have..... but before you condemn the sender maybe check the wiring connection there for corrosion also the connection to ground thru the sender itself. Good luck man I hope someone has a number for you.
Has thanked: 468 times
Been thanked: 1765 times
Postby Viper » June 9th, 2025, 7:02 pm
Ya I would check the wiring first, looks corroded, that could give you inconsistent readings.
KuyaJunGarage
Postby KuyaJunGarage » June 10th, 2025, 10:56 am
Morning, BUD37 & Viper, thanks for the reply and suggestion. Will try this, awesome thank you guys.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 143 times
Been thanked: 134 times
Postby KyleR » June 10th, 2025, 11:47 am
Try www.sbmar.com
They are pretty much the go-to source for all things Cummins. Especially check out "Tony's Tips" to really get to know your engine.
Good luck!
MV Verity
2002 Carver 396
