360 sport sedan shore power
Olmsr8j1
Topic author - Scurvy Dog
- Vessel Info: 2004 Carver 360 sport sedan
- taddly
- Vessel Info: 2003 Carver 360 Sport Sedan
Re: 360 sport sedan shore power
Our mechanic suggests a complete redo with traditional boat side hook ups . Surely there is an easier way.
Thanks .
2017 MerCruiser 383 MAG Strokers
- waybomb
- CYO Moderator
- Been thanked: 490 times
Is this a Cablemaster, where the cord is reeled in or paid out via a motorized reel?
If so, check out the Glendenning website above for support.
- taddly
- taddly
Looks like it might have been cut/ pinched by the door on the swim platform which is meant to hide the cord , since by design has a long rough edge to it. I called Carver, and apparently the power cords are hard wired to the forward breaker box. They even admitted it is a bad design overall and tough to replace ! Unbelievable !!
Thanks Viper for the input !!
- waybomb
- CYO Moderator
So, is there room to install a regular shore power inlet at that bulkhead?
If so, snip the wire about a foot out of the bulkhead, and cut out for a shore power inlet. If you can't find a way to the backside of that bulkhead to hold locknuts, then you could glass in some marine plywood to the backside and use stainless wood screws to hold the shorepower inlet in place. Then take the snipped off cord, strip it back, and connect it to the shorepower inlet.
- taddly
We have our mechanic looking at doing the same as you recommend above. Will Keep you posted .
- taddly
We did cut the original power cables & installed two transom compartment mounted bulkhead connectors. We now have a more or less normal shore power cable architecture. Works perfectly.
