Hot water tank not filling with water
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Hot water tank not filling with water
Make sure the drain spigot near the bottom of the tank is closed.
On my water heater water intake lines, I have 2 valves I can turn on and off to bypass the heater when winterizing. If I recall, one has to be open and the other closed, but not positive. $5 says you have those same 2 valves and they simply aren’t in the correct position.
- Has thanked: 602 times
- Been thanked: 1311 times
It'll be something real simple/missed I think on startup, we all have done it ....
- buster53
tgebler wrote:Source of the post I have a 2000 396 Aft cabin. I know this is a strange question but my hot water tank does not appear to be filling. I reconnected the hoses after the winter and hooked to shore water. I then turn the spigot in the head to hot water and nothing came out. Help!!
So, any updates?
