450 Voyager planing speed
- ck36
- Vessel Info: 2002 Carver 450 Voyager, TAMD74P
- Has thanked: 17 times
- Been thanked: 4 times
I'm still trying to determine the cause of smoking which on my last outing occurred on speeds up to 2000 RPM which was about 14 knots. (I recorded 11.8kts at 1850RPM and 15.5knts at 2200RPM). 4 people aboard, 750lb dinghy, 200 gallons of fuel, bottom not heavily fouled but probably some soft growth.
Re: 450 Voyager planing speed
- ck36
- Has thanked: 602 times
- Been thanked: 1310 times
A couple more questions, is this something ( the smoking ) that has just started since the sea trial, then just be sure as I think you are to cross off the simple stuff first....like clean bottom, clean filters , is the boat propped correctly.
My understanding, black smoke is generally fuel related but can be due to the load trying to get on plane.
- ck36
I focused on air first, cleaned filters, ran without them, ran with engine hatch open. No change.
Yes this boat is new to me and I didn't notice any residue after taking her out on the survey run, but dinghy was not onboard at the time and perhaps we didn't run at the slower speeds. I did find a note from the prior owner that he experienced a lot of soot build up on the transom running at 1800 rpm - but no details on what he noticed above and below that point.
The bottom and props appeared clean when hauled out in May, but probably some soft growth on now.
I opened the fuel tanks and other than a light residue on the tank sides (I can write my initials on the sides with my finger) there was no water in the tank and nothing looked out of the norm. The fuel was loaded in Sept 2024 (full tanks) and so I've burned down to 1/4 tank and treated with Biobor MD and JF but haven't run since doing that.
Not sure about the other Carvers, but this one did not have any turbo boost gauges. I installed the YDES gateways on both engines and just got them both working today so now I have turbo boost and fuel flow. Going out on a run tomorrow to test things out.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
As far as cruising speeds go, whatever you do, do not cruise between hull speed and full plane. For your boat, I’m guessing hull speed is about 8.5 knots. Full plane, at least 17. Anything in between, you are wasting fuel and pulling a big wake which won’t make you any friends
- ck36
Viper wrote:Source of the post Ya the wastegates are a consideration for sure. Also consider the charge air coolers. They're raw water cooled and could be restricted, especially in a salt water application. Check the easy stuff first.
I hadn't thought about the CAC's but definitely need to check those.
- ck36
buster53 wrote:Source of the post Ok, your location says Washington. Is that DC or State? Fresh, salt or brackish water? You say bottom looked good in May and maybe some soft growth since then, If you are in salt, you probably have hard growth on your running gear. You’d be surprised what can grow in 2-3 months especially on running gear.
So that's interesting, I read where people cruise at "economical" speeds and if I'm doing 17 I feel like I'm being somewhat extreme. At WOT I can do 20knts so I'm running at the upper end at those speeds. When I take her out tomorrow I will definitely play around with my speeds.
Oh and I live in Washington, in salt water. I'm going to check my props tomorrow with a boroscope. I have an inexpensive one that has come in very handy for everything from running NMEA cable to checking turbo condition. It's waterproof so I should be able to check prop condition before heading out.
- buster53
ck36 wrote:Source of the postbuster53 wrote:Source of the post Ok, your location says Washington. Is that DC or State? Fresh, salt or brackish water? You say bottom looked good in May and maybe some soft growth since then, If you are in salt, you probably have hard growth on your running gear. You’d be surprised what can grow in 2-3 months especially on running gear.
Ok, if 20 knots is you WOT, that has some affect on what I said since 17 is getting close to you WOT. With my boat, and a nice clean bottom, I can hit 30 knots, gas engines. I normally cruise in the 19 range. I can pretty much guarantee, I get way better fuel economy at 18-19 than I would at 11-15.
4-5 years ago, I splashed my boat late April. Boat yard must not have used a good running gear paint because in 10 weeks, I lost 6 knots of speed due to barnacle growth, I had to do a short haul to clean everything. Couldn’t believe how bad my running gear looked. It was obvious why I lost 6 knots of speed
