Drain tube splash guard
CooperB
Vessel Info: 2006 39my
Postby CooperB » August 14th, 2025, 7:01 pm
2006 39my - I’ve been looking for this rubber fitting for two years. It located on the exterior near the window on the aft deck. I don’t even know what you call it. The attached picture may be coming in sideways. Any suggestions on what it is called and where to find a replacement? Much appreciated!.
Re: Drain tube splash guard
Postby Viper » August 15th, 2025, 6:51 am
Welcome aboard.
That looks like a hooded drain thru-hull fitting. See if Marine Town still carries them....
https://www.marinetown.com/
Postby Viper » August 15th, 2025, 7:01 am
Here's one I found on-line which looks like the one but am unsure about the size and it's overseas. I see the brand is Marine Town too, so we might be on to something....
https://www.mtonauticastore.com/pvc_sea_discharge
CooperB
Postby CooperB » August 15th, 2025, 9:17 am
Thanks for the leads. I’ll be calling Marine Town!
Postby Midnightsun » August 15th, 2025, 12:06 pm
Those seem to have either a 25mm ODF or 32 which I doubt the hose connected to it is that big. Verify the hose size before ordering anything IMHO. Probably better off with a fuel vent in chrome or stainless. At least those will look good for decades to come unlike the PVC one that looks bead afetr a few yers in the sun.
That being said, the fuel units are made for 5/8" hose, worst case scenaron is you will need to enlarge or reduce the hose size if i is not compatible with the OEM size hose.
Here are some examples. Perko makes one that is quite similar to the existing model if you scroll down a bit.
https://defender.com/en_us/catalogsearc ... ule%20vent
Seadog also has one available made of Nylon which would hold up much better then PVC. Only available in black though.
https://www.boatid.com/sea-dog/straight ... 5395218276
Postby bud37 » August 15th, 2025, 12:56 pm
To add.
Another way to clean it up if you want , just fit a clamshell cover over that broken end there just leave the existing where it is.. They come in all kinds of sizes, finishes.
Postby Midnightsun » August 15th, 2025, 1:35 pm
bud37 wrote:Source of the post To add.
Excellent suggestion. :clap:
Postby Viper » August 16th, 2025, 9:07 pm
Ya I agree with both the above, you're better off switching to stainless steel even if it's not the same design.
Users browsing this forum: No registered users and 62 guests
