Vetus wet muffler
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Vetus wet muffler
Re: Vetus wet muffler
https://www.fisheriessupply.com/centek- ... -separator
Looks like Vetus has it's on take on the same solution and maybe what you refer to.
https://webshop.vetus.com/en/products/e ... separators
Carverlvr2
- Vessel Info: 2004 Carver 366, VP 8.1’s
1979 Searay Sundancer 260 - Location: Shelbyville, IL
- Been thanked: 25 times
- Been thanked: 1111 times
Carverlvr2 wrote:Source of the post My 2004 Kohler 7.3e is also super quiet with the hatches closed. Has a water lift muffler that exits out under the boat. The good is that it’s super quiet. The bad is, from the few times I’ve run it, I can’t tell if it’s pumping water or not so if the impeller or pump ever fail, I won’t know till it overheats and shits off. Anyone have experience or suggestions with these?
I have not done this, but it would seem you could locate a pressure gauge or sensor on the output of the raw water pump and get an idea of what appropriate numbers would be when it's running correct with a new impeller, and be able to tell when it's insufficient.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 54 times
- Been thanked: 32 times
One thing for sure, if its not pumping it will shut down automatically is about 2 minutes.
I think it short sighted of Kohler that they don't have a temperature guage.
Kohler no long makes marine , gas generators.
At least I know its working (cooling) when I winterize it because it takes in the the 3 gallons of non-toxic anti-freeze that I flush it.
