Engine maintenance
MyPleasure
Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
Been thanked: 23 times
Engine maintenance
Postby MyPleasure » September 11th, 2025, 12:45 pm
Hi everyone,
I think that I’m fairly knowledgeable about gas engines, at least I thought that I was until recently. One of my Volvo Penta 740b engines started missing on our latest trip, and I was shocked to find that both distributors had rusted so badly that the advance weights were frozen and the springs were actually missing.
I had changed the spark plugs last year and the engines seemed to be running fine, I thought, so I never even thought about a problem with the distributors.
Never take for granted that things are perfect under your distributor cap, be thorough when you’re doing a tune up on your engines!
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
thatchh
Vessel Info: 2004 Carver 396ES gas Crusader 8.1
Has thanked: 5 times
Been thanked: 11 times
Re: Engine maintenance
Postby thatchh » October 15th, 2025, 2:41 am
Wow! Were the caps missing their gaskets? Seems like way too much moisture got inside. Without the gaskets, there is a possible vapor ignition risk.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Postby pepmyster » October 15th, 2025, 6:59 am
Wow. Never saw them that bad. Saltwater in the air? I see your from BC. Either sand blast them or replace, depending on the cost. Good that you found this!
