Onan generator field breaker replacement
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 143 times
Postby KyleR » September 22nd, 2025, 12:18 pm
Hey everyone. My circa 2002 Onan generator (10KW Model MDKWB) has a bad field breaker. Unfortunately there are no real identifying specs on the breaker itself other than the manufacturer, Airpax, and a bunch of patent numbers. (See pics attached)
I did find a part number in the parts manual: 320-1769. Unfortunately trying to search that hasn't yielded much either.
If I could get the specs/ratings I can get a like-for-like part, which is probably my best hope. I'm just not sure what ratings to look for.
I reached out to Airpax but no reply yet.
Thanks in advance!
Kyle
MV Verity
2002 Carver 396
KyleR
2002 Carver 396
Re: Onan generator field breaker replacement
Postby KyleR » September 22nd, 2025, 1:21 pm
Followup: I called Onan on a whim and that part number is actually still active and a available, for nearly $75! Typical though of my experience with other Onan parts.
However, I did find out it is a 5amp breaker so I am thinking about using this:
https://a.co/d/f6IWxua
Any electrical gurus out there have any insights on if this would possibly be an acceptable replacement? Thanks again!
MV Verity
2002 Carver 396
Postby km1125 » September 22nd, 2025, 1:42 pm
I'm surprised there are no other markings on the old breaker!! I don't think I've ever seen one that doesn't have at least the basic ratings for the device, much less an actual part number.
Where did you come up with the 5A number? If that is the rating of the old breaker, or the field never exceeds 5A, then I'd bet that new breaker in the link you posted would be fine.
KyleR
2002 Carver 396
Postby KyleR » September 22nd, 2025, 2:04 pm
Me too! I thought this was going to be pretty simple - but nothing is! :lol:
It was listed in the description on the Onan parts website. No other specs though (e.g. voltage, time delays, etc).
Thanks for the feedback!
MV Verity
2002 Carver 396
