Cummins 6BTA Coolant Flush
- 650Guy
- Captain
- Been thanked: 40 times
Has anyone figured out a way to do that in the 6BT engines? man that would be a big help!
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
Re: Cummins 6BTA Coolant Flush
https://quickserve.cummins.com/info/index.html
Attached is a pic of the drain location.
Kyle
2002 Carver 396
- 650Guy
- Captain
Did you just swap it with the old green stuff or did you convert to the newer red? From what I read the red last longer but I have to do a complete flush to switch.
- KyleR
2002 Carver 396
The only difference from my pics is that I ended up using concentrated version as it was significantly cheaper to buy it and then get a few gallons of DI water for dilution. From what I remember each engine including the HX holds almost 6gallons.
Kyle
2002 Carver 396
- 650Guy
- Captain
