Props for 390 Cockpit Motor yacht
NJboater65
Vessel Info: 1995 390 cockpit motor yacht
Postby NJboater65 » October 1st, 2025, 1:44 pm
I'm purchasing a 1994 390 Cockpit motor yacht. The props are shot, maybe beyond repairing. Does anyone know what the correct factory size prop is? Or a recommended size that works better. The ones on there are 22 x 22, Rpm's are lower than they should be. Not sure if it's a prop or motor issue so checking both out.
Been thanked: 285 times
Re: Props for 390 Cockpit Motor yacht
Postby buster53 » October 4th, 2025, 4:09 pm
So, what engines are in the boat?
