toilet wont hold water.
Topic author
donr
Vessel Info: 2002 Carver 346/366 MY aft cabin
Postby donr » September 20th, 2014, 7:47 pm
I have 2 Thetford elecric toilets on my boat.
Both fill and flush OK but neither will hold water in the bowl it just leaks out.
I have tried a couple of bottles of seal conditioner with no resuts, since it leaks out also.
I thought about removing the discharge hose and plugging it up to hold the seal conditioner until it has more effect but I,m hesitant to try that.
Parts no longer seem to be available either.
Thanks Don
2002 346 MY
Been thanked: 489 times
Re: toilet wont hold water.
Postby waybomb » September 21st, 2014, 8:24 am
Forget the liquid fixes for just about anything. There's only one solution; rebuild it. EBay is your freind. Search ebay for Thetford. Many seal kits show up. You will have to figure out which model you have so you can select the correct kit.
Rebuilding heads is easy. I just did my Crown.
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » September 21st, 2014, 7:49 pm
As Fred said - those seal additives are a joke. Bet you can buy the seal kit for less than what you have paid on additives.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Users browsing this forum: No registered users and 144 guests
