Cored hull?
- tonyiiiafl
- Has thanked: 593 times
- Been thanked: 175 times
Cored hull?
Has anyone used the transom mount transducers? Not a lot of room there where it could be mounted with not interference from teh wash/wake?
Thanks!
- Has thanked: 432 times
- Been thanked: 1599 times
Re: Cored hull?
- tonyiiiafl
Re: Cored hull?
I am digging in.
- Has thanked: 60 times
- Been thanked: 979 times
Re: Cored hull?
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 112 times
- Been thanked: 38 times
Re: Cored hull?
Don't use transom mount, they're not ideal for inboard applications.
See my recent post on 406 Navionics upgrade
viewtopic.php?f=10&t=7707&p=60463#p60463
I have the Garmin Transducer GT54UHD-TM and a Airmar M66 transducer (Re-used existing for 50/200 Mhz).
I get a great result at all speeds withe the TM. If you want to see a video, I can make one on my next outing.
Lake Lanier GA
1999 Carver 406
Re: Cored hull?
- Has thanked: 550 times
- Been thanked: 1151 times
Re: Cored hull?
FYI.....I have epoxied a lowrance wide angle transducer to the inside of a cored hull and it worked just fine. The above is the method I used to find a good spot first.....good luck.
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
Re: Cored hull?
bud37 wrote:Source of the post If you want to find out if it works as shoot thru......just pick your spot following the guidelines , put the ducer in zip lock bag full of water and put in contact with the hull, see if you get a good result.
I second this method. I’ve secured more than a few transom mount transducers with clear silicone adhesive to the bottom of the bilge and got accurate readings for depth. Water temp readings will be close enough for government work.
Users browsing this forum: No registered users and 7 guests
