Cored hull?
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Cored hull?
Has anyone used the transom mount transducers? Not a lot of room there where it could be mounted with not interference from teh wash/wake?
Thanks!
Re: Cored hull?
- tonyiiiafl
Re: Cored hull?
I am digging in.
Re: Cored hull?
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 197 times
- Been thanked: 55 times
Re: Cored hull?
Don't use transom mount, they're not ideal for inboard applications.
See my recent post on 406 Navionics upgrade
viewtopic.php?f=10&t=7707&p=60463#p60463
I have the Garmin Transducer GT54UHD-TM and a Airmar M66 transducer (Re-used existing for 50/200 Mhz).
I get a great result at all speeds withe the TM. If you want to see a video, I can make one on my next outing.
1999 Carver 406
Re: Cored hull?
- Has thanked: 602 times
Re: Cored hull?
FYI.....I have epoxied a lowrance wide angle transducer to the inside of a cored hull and it worked just fine. The above is the method I used to find a good spot first.....good luck.
- Hoplite808
- Vessel Info: 1988 Carver 3227 Convertible
- Has thanked: 1 time
- Been thanked: 8 times
Re: Cored hull?
bud37 wrote:Source of the post If you want to find out if it works as shoot thru......just pick your spot following the guidelines , put the ducer in zip lock bag full of water and put in contact with the hull, see if you get a good result.
I second this method. I’ve secured more than a few transom mount transducers with clear silicone adhesive to the bottom of the bilge and got accurate readings for depth. Water temp readings will be close enough for government work.
