Rudder angle indicator
Posted: April 1st, 2019, 10:59 am
by tgebler
I have a 2000 396 aft cabin and the rudder angle indicator does not work. Any thoughts about how to get this gauge working again. Any help would be appreciated.
Re: Rudder angle indicator
Posted: April 1st, 2019, 1:59 pm
It'll either be the gauge, wiring, or sender. First check and insure the sender hooked up to the rudder in the aft cabin is actually hooked up and moves freely and does a full sweep when the wheel is turned. With the rudders centered, the sender should be in the middle of its sweep. If all looks good back there, with the power on, short out ground and the sender terminals at the back of the gauge. The gauge should peg. If it does, chances are the gauge is fine, and there's an issue with the sender. Make sure all connections at the sender and gauge are clean and tight.
What brand of unit is it? Besides the gauge, is it hooked up to any navigation screen, autopilot, etc. also?
Posted: April 1st, 2019, 2:58 pm
by tomschauer
I assume you have verified you have power? Most likely tied into one of the ignition circuits or an accessory circuit. If so, follow Vipers suggested checks.
Posted: April 1st, 2019, 5:54 pm
by tgebler
Thanks for the help. I will try these things the next time I am down at the boat.
Posted: July 22nd, 2020, 6:52 am
Did you get this figured out??
Posted: July 22nd, 2020, 8:42 am
by buster53
Curious as well. My rudder indicator doesn't work either on my 356.
Posted: July 22nd, 2020, 11:45 am
buster53 wrote:Source of the post Curious as well. My rudder indicator doesn't work either on my 356.
I cannot remember what dash gage houses the display........do you have the multiple display that has the rudder position with another display , or is it on it's own ?
