Rudder angle indicator
tgebler
Vessel Info: 2000 396 AC
Has thanked: 5 times
Been thanked: 29 times
Postby tgebler » April 1st, 2019, 10:59 am
I have a 2000 396 aft cabin and the rudder angle indicator does not work. Any thoughts about how to get this gauge working again. Any help would be appreciated.
Re: Rudder angle indicator
Postby Viper » April 1st, 2019, 1:59 pm
It'll either be the gauge, wiring, or sender. First check and insure the sender hooked up to the rudder in the aft cabin is actually hooked up and moves freely and does a full sweep when the wheel is turned. With the rudders centered, the sender should be in the middle of its sweep. If all looks good back there, with the power on, short out ground and the sender terminals at the back of the gauge. The gauge should peg. If it does, chances are the gauge is fine, and there's an issue with the sender. Make sure all connections at the sender and gauge are clean and tight.
What brand of unit is it? Besides the gauge, is it hooked up to any navigation screen, autopilot, etc. also?
Postby tomschauer » April 1st, 2019, 2:58 pm
I assume you have verified you have power? Most likely tied into one of the ignition circuits or an accessory circuit. If so, follow Vipers suggested checks.
tgebler
Postby tgebler » April 1st, 2019, 5:54 pm
Thanks for the help. I will try these things the next time I am down at the boat.
Postby Viper » July 22nd, 2020, 6:52 am
Did you get this figured out??
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » July 22nd, 2020, 8:42 am
Curious as well. My rudder indicator doesn't work either on my 356.
Been thanked: 1310 times
Postby bud37 » July 22nd, 2020, 11:45 am
buster53 wrote:Source of the post Curious as well. My rudder indicator doesn't work either on my 356.
I cannot remember what dash gage houses the display........do you have the multiple display that has the rudder position with another display , or is it on it's own ?
Users browsing this forum: No registered users and 43 guests
