Location of Water Shut-off
- Sailor Jerry
- Vessel Info: 1996 Carver 355
- Has thanked: 2 times
- Been thanked: 8 times
- Contact:
- Been thanked: 601 times
Re: Location of Water Shut-off
Tom
- Sailor Jerry
- Contact:
Thanks, Jerry
- Has thanked: 469 times
- Been thanked: 1765 times
The shore water inlet may also freeze so you may want to cap the line to it but you should blow through it also so that any water in the valve/regulator doesn't split it too.
Do you have an ice maker or sink in the cockpit that will be exposed to freezing temps too that you need to be worried about also?
If I were in the same conditions, I would plumb in shut-off valves in an accessible space in the boat with a means to drain those lines like a T and drain valve. This would make it easy to prep for winter without having to undo lines every year.
- mjk1040
- Been thanked: 246 times
- Sailor Jerry
- Contact:
- mjk1040
- Been thanked: 646 times
- nightsky
- Vessel Info: '94 Carver 390 cpmy
- Has thanked: 6 times
- Been thanked: 16 times
Users browsing this forum: Google [Bot] and 15 guests
