Transmission Repair Started
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
I asked him since he was working on the port tranny could he also replace the fluid in the starboard tranny. That way I will know that the fluid in both transmissions was replaced at the same time.
He said he will keep me abreast of the repair as it progresses. He expects that the repair will be under 2 K. I do hope so.
Now I can start thinking of spring launch with both transmissions in working condition.
2022 Stingray 182 SC
- Has thanked: 468 times
- Been thanked: 1765 times
Re: Transmission Repair Started
- RGrew176
- Been thanked: 601 times
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
I was thinking the same as mine is still in the shop for the SB trans and I'm at $5500, keeping in mind I have a 98 Caver Mariner and anything engine\Trans related is a PITA!!!
- RGrew176
- RGrew176
The final cost parts and labor, $2355.18. A bit more than quoted early on but I am satisfied with the final cost of the repairs. I did add on to have the fluid in the starboard transmission changed at the same time. I figure that if one transmission died just how long will the other one run before it needs to be repaired. Hoping the transmission fluid change in the other transmission will buy me some time. Now I know when both had fluid changes. Buying the boat used I have no idea when that was last done.
I am told by people at the marina who knew the previous owner that he was pretty anal about maintenance of the boat while he owned it and it does show.
Looking forward to launching sometime between April 1st and 15th. Come on spring.
- RGrew176
tomschauer wrote:Source of the post Rick, what did they find inside the tranny?
The clutches were fused and there was some other part that needed replacement. I forget what they called it.
- SanJuanDreamer
Users browsing this forum: CBBrew and 28 guests
