Installing Flooring in Carver Mariner
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Installing Flooring in Carver Mariner
SeaDragon
- Has thanked: 469 times
- Been thanked: 1765 times
TonyC
- Vessel Info: 1998 Carver 350 Mariner
- Has thanked: 22 times
SanJuanDreamer wrote:Source of the post Let me know what you find on the softspot.
Mine is in front of the stairs/salon table.
Don't notice it until I'm standing in front of the table and someone walks by.
Will do. Working on the boat this weekend and will take another look and post back.
Tony
- cpoint
- Has thanked: 208 times
- Been thanked: 31 times
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
cpoint wrote:Source of the post This is a project I am starting on as well on carver 356. After long decision process decided to go along with so called luxury vinyl plank flooring. Purchased couple boxes, waiting on warmer weather before I start as its pretty cold here now. I agree on the trimming around hatches, I think it looks better without. Depending on how well and clean I can make the cuts, I plan on using no trimming on hatches. Also on 356 there are lots of hatches, I am thinking of combining at least the 4 hatches over engines into 2 hatches, so there will be single hatch over each engine.
Are you using anything between the boat floor and the vinyl plank?
- cpoint
- Been thanked: 601 times
One of the reasons I didn't tackle this project yet.
- SanJuanDreamer
- mjk1040
- Been thanked: 246 times
- cpoint
tomschauer wrote:Source of the post I think without some sort of trim around the hatches you will be left with some pretty big gaps. The carpet is wrapped around the edges, I would guess it takes up close to 3/8" between backing, and fibers on each side of the joint, that would leave you with a 3/4" gap more or less. I doubt you can wrap the adhesive flooring without cracking the face on a tight 90 bend.
Yes that's why I am still in planning stage. Once I remove the carpet and find the actual gap size, I will see if I can patch with thin strips or may consider re-cutting a new hatch that's a perfect fit. later one would be last resort though. as far as planks I am talking about, they are fairly thick, minor bumps under it or edges will not be an issue. I will be doing the gaps around 1/8 inch or close to that as I possibly can. Definitely will be tricky project, but outcome should be nice.
