Small boat big big project!
Re: Small boat big big project!
- hardchines
- Vessel Info: 1980 Carver
2667
Santa Cruz - Has thanked: 8 times
- Been thanked: 29 times
- hardchines
2667
- hardchines
2667
2 Garmin 546s GPS depth one up one down, WAAS
1 Garmin 180 B/W GPS depth in V-bunk area, anchor drag alarm and shallow water alarm, WAAS
2 Uniden VHF radios, one up one down
1 Standard VHF radio at V bunk, auto weather alert radio
1 Ratheon S1000 auto pilot, wireless remote cradle up and down
1 Furuno radar, display is up.
1 remote spot light, controls up and down
1 Lewmar chain and rope anchor windless, switch up and down plus hand held wireless remote
1 9000 BTU AC with resistance heat coils
1 large marine cabin heater, hot water from engine with electric boost circulation pump
2 12 x 24 inch Bennett trim tabs, duel controls
1 30 pound stern thruster switch up and down with wireless hand remote
1 Next Gen 3.5 KW (30 amp) diesel generator, water lift muffler and full sound shield
1 26 inch RCA flat screen tv
1 Raritan 1700 hot water tank, 120 volt plus heat coil supplied by engine water
1 large auto discharge Halon fire fighter in engine room with dash ready light
1 Sealand 711-M28 head with 10 gallon integrated holding tank
1 20 amp battery charger
3 group 31 deep cycle batteries, 2 for house, 1for start
1 Yanmar 4TNV86 43.5 HP, 100 ft torque diesel coupled (custom) to Mercruiser Alpha one Gen2, 1.98 to 1 ratio outdrive
1 Dometic duel voltage refrigerator
1 power inverter 880 watt with fail safe auto voltage isolator with bulkhead mounted digital display panel, volt,watt,amp
1 flowtec raw water wash-down pump, raw and fresh water on for-deck 1/4 turn sill cocks
1 Perko sea-cock and strainer
1 Dahon marina folding bike in case stored inside of flybridge
1 lightning rod,1 inch dia x 6 inch long SS (sharp point) mounts to fold up fiberglass pole, second glass pole swings out to hold 40 cable 4 feet from side of boat, cable is attached to large copper plate that is suspended under water at end of cable.
1 6 1/2 foot glass dingy by skimmer
1 Yamaha 3.5 hp outboard
1 rail mount Magma propane grill
1 2 burner electric stove with alcohol option
1 Dometic ice maker
1 wireless remote anemometer, temp, barometer
1 BSA 6 man life raft, in canister and stern rail mounted SS quick release cradle
- hardchines
2667
diesel 103 gallons
fresh water 61 gallons
black water 44 gallons
LOA 30 feet
Hull length 25' 10"
waterline 21
Aft freeboard 39"
forward freeboard 39"
Beam 8'
Trans beam 7'6"
Draft 3'
air draft minimum 8' 9"
weight full fuel and fresh water 8072 lbs no carry on equipment, dingy, raft or supplies
normal cruise speed 6.1 MPH @ 1800 RPM. 10 MPH estimate @ Max 2600 RPM
normal cruise mileage 8.4 MPG
The MPG is actual 1000 mile trip data. this trip included 70 lockings, engine never shut down during locking.
My estimate is 9 MPG if not locking, or at least close.
Fuel burn at normal cruise .73GPH
range at normal cruise 840 Miles plus 3 gallon reserve, 900 miles if not locking
Generator fuel burn @ half load .2 GPH Air Cond, and batt charger on
generator max run time at 1/2 load 500 HRS.
- edcourter
- Vessel Info: 86 2667
- hardchines
2667
- hardchines
2667
- edcourter
- hardchines
2667
I launch my boat the day I leave on my trip, this year I hope to do the Trent Severn waterway in Canada, Round trip and then some other canals in Canada if time and conditions are right. Its Canada's 150th birthday and to celebrate , locking is free this year!!!
