Sundeck Corner Trim Elbows
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
I originally hail from New Jersey along the shore and in the middle of many boat manufactures such as Ocean, Egg Harbor, & Viking to name a few. I'm working with a plastics machining & fabrication company in NJ to make replacement corners with a UV inhibitor for sun & saltwater use on my boat. Once we figure out the best way to make new corners, I will have them made and provide a resource to the forum for others in need of replacements.
Attached is a photo of my remaining corner.
- mjk1040
- Been thanked: 248 times
Re: Sundeck Corner Trim Elbows
- Wayne162
- Captain
- Contact:
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
I would look at extruding companies who offer a multitude of extruded profiles and materials to accommodate our marine environment. Google "plastic corner extrusions", you should get a large selection of companies with catalogs showing a large selection of profiles. Determine your corner radius dimension and mating material dimension. Companies can help search for profiles and select the material and provide material shades. You could come very close with a profile that could work. Minimum qualities could prohibit cost justification? But tooling and machining cost on a custom is very expensive also. Hope this helps Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Wayne162
- Captain
- Contact:
- rkrumm
- Vessel Info: 1995 430
- Has thanked: 1 time
Anacortes, WA
1995 Carver 430
- Wayne162
- Captain
- Contact:
IdleDrifter
- Vessel Info: Carver 355
- Wayne162
- Captain
- Contact:
Users browsing this forum: Rocketman and 31 guests
