all batteries dead
eRock1
Topic author - Scurvy Dog
- Vessel Info: 89 carver 3207
all batteries dead
Hindsons penetanguishene ontario
- Has thanked: 469 times
- Been thanked: 1765 times
Re: all batteries dead
It's the new world order!
If they're dead now, they're likely toast or at best won't have the capacity to hold a decent charge for long, if they'll even take a charge at all. Change them so they don't let you down next season.
You've probably got two battery banks; a start bank designed to start the engines, this may consist of one or more start batteries in the same bank, and the other bank that should be deep cycle batteries (your 6 volt batteries) designed to run house loads.
Unless you know how the boat is wired, and by this I don't mean the OEM schematics because there is no telling what a previous owner did, I wouldn't trust that simply turning the battery switch off shuts down ALL DC loads. When in doubt, for winter, disconnect the negative cables at the batteries.
There are way too many variables involved to determine why they failed but you can minimize the chances of failure by putting them to bed properly to begin with. If nothing was done to them prior to winter, that's part of the problem.
If you're going to invest that kind of money to replace 4 x 6 volt batteries, consider replacing your charger to a smart charger if you don't already have one. Spending that kind of cash for batteries without a proper charger to maintain them is poor economics. I know the wallet dictates, and if you have to skimp somewhere, do it on a less critical system.
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
And welcome to the neighbourhood. As you can see we are next door at Beacon Bay.....
We are getting to the point where could have a Carver Forum floatilla
Cheers
Fraser
eRock1
. I will try to charge them but I'm thinking they're done. Might see if the Marin will let me plug in to charge them up.Hindsons penetanguishene ontario
- mjk1040
- Been thanked: 246 times
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
eRock1
- Has thanked: 598 times
- Been thanked: 1281 times
