Carver 1/8" or 3/16" SS cable swage tool
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
I bought the swage tool and can make it available to anyone wanting to crimp 1/8" or 3/16" cable. Not sure if I will use it again? Only ask it get sent back after use. Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Re: Carver 1/8" or 3/16" SS cable swage tool
- Been thanked: 654 times
- dsolo
454 EFI Crusaders
S0708-0307, SS wire PVC 316, 7x7, 1/8"x1/4". 37'
S0737-H003, SS hand Swage toggle terminals 1/8" 8ea
S0732-H0703, SS hand Swage Stud 1/8" wire LH. 8ea
The left handed treaded stud threads into your existing spring clasps. Saves a lot money if you can reuse them.
Cable is $.83 per foot.
Toggle terminals are $9.44 EA
Studs are 6.75 EA
The swage tool is held in vice and has two grade 8 bolts between two jaws. Insert terminal into jaws, cable into terminal, ratchet bolts to close jaws and form crimp on terminal. Rotate terminal 180 degrees and I crimped each terminal 4 times alternating each crimp 180 degrees. Better looking than the factory crimps.
Your more than welcome to the tool.
Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
