Boat will not plane
nolacarver
Topic author - Scurvy Dog
- Vessel Info: 1979 33' carver
New Orleans, LA
Boat will not plane
- Been thanked: 490 times
Re: Boat will not plane
What is the rpm at WOT?
What has the yard done so far other than what you've mentioned?
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
T-Merc 350 Mag MPI (300hp)
nolacarver
New Orleans, LA
nolacarver
New Orleans, LA
If it has been sitting a long time (1+ years), I'd rebuild both carbs.
Is the gas new or also old?
Does the fuel smell like gasoline or varnish.
How long was the boat out-of-use?
nolacarver
New Orleans, LA
Rebuild both carbs. If you take them off and put them back on, they shouldn't charge you more than a hundred bucks each.
But make sure they rebuild <your> carbs. The carbs may look the same from the outside, but there three different fuel rod sizes, a number of different rod springs, etc.
And make sure when they rebuild the carbs, they epoxy shut the plugs on the bottom - these are pressed/swagged in plugs that close off holes needed for drilling passages inside the carb. They are notorious for leaking over time. The accepted way to fix this is to epoxy them in. Do not rely on the new rebuild kit gasket inserts - they do not work. You can google "rochester plug" and you'll get a bazillion hits on how to do it right.
nolacarver
New Orleans, LA
