upgrade electronics
EMIT REEB
Topic author - Scurvy Dog
- Vessel Info: 32' 1988 Carver aft cabin
- Has thanked: 5 times
upgrade electronics
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: upgrade electronics
I ended up with this GPS unit:
https://buy.garmin.com/en-US/US/p/529894
This was the old early 90's or late 80's GPS unit.
This is a pic of the new unit:
I ordered mine without the transducer. I wanted a dedicated GPS. The 9" screen is really nice and the detailing of the charts is very good IMO.
I also installed a new VHF with DSC. The DSC is a good safety feature. If you are in trouble you push the red button and it will transmit your location.
I would recommend both units as I am very happy with both of them. I also bought and installed a new VHF antenna. Prior to the new antenna I could pick up 3 of the 10 weather channels in my area. Now I get 7 of 10. Last season out on Lake Erie I was able to listen in to radio conversations 40 miles away quite clearly. Get a good VHF and get a good antenna so the radio can function at its best level.
I was contemplating replacing the depth sounder. The one that came with the boat is ancient tech but it still works. All I want out of a depth sounder is how much water is under the hull. So, as long as it keeps working I will continue to use it.
Here is a pic:
It has an in hull transducer and comparing readings to the chartplotter depth readings it is accurate.
Midnight Sun
- Vessel Info: 2007 Carver 41 CMY D6 370's
- Has thanked: 1 time
- Been thanked: 3 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
The Garmin 741xs is popular now - it's a nice unit and not overly-expensive. You can also update it with radar that is plug and play if you want. It has Wifi and network capabilities too. Worst Marine has it on sale now for under $900. You may be able to use the existing transducer for depth - it depends on what frequency the old one is. Or you can add a shoot-through transducer or cut a hole and use a through-hull transducer. Running the transducer cable from the bridge down to the hull can be a challenge...There is a lot of good electronic stuff out there today - look carefully, get some advice, and you can find something that will suit you well.
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Hunt_trex
- Vessel Info: 1999 Carver 356 "Vader"
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
http://www.carveryachtowners.com/viewtopic.php?f=10&t=2187
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- SplashyLady
- Captain
RGrew176 wrote:I was contemplating replacing the depth sounder. The one that came with the boat is ancient tech but it still works. All I want out of a depth sounder is how much water is under the hull. So, as long as it keeps working I will continue to use it.
Here is a pic:
Wow - a nixie bulb depth finder! Those nixie tube readouts were state-of-the-art in their time! The originals were in vacuum tubes back in the late 50s and early 60s - then they evolved to the version you have in the 1970s-1980s. They disappeared and were replaced by LEDs and LCDs in the 1980s, but were still used in Russian-made electronics into the 1990s. But it's still cool to see them! BTW- they work similar to a neon tube and have a long life - they can last 30-40 years under the right conditions!
Lake Norman, NC
Users browsing this forum: No registered users and 56 guests
