I knew Tabman would have the answer - not a FUBAR after all. Thanks to all for teaching the old guy a new trick.Welcome to Carver Yachts Owners Forum
Trim Tab Brace
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Re: Trim Tab Brace
I knew Tabman would have the answer - not a FUBAR after all. Thanks to all for teaching the old guy a new trick.Past Commodore, Peninsula Yacht Club
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- SplashyLady
- Captain
Re: Trim Tab Brace
Tabman wrote:Source of the post Yup, it is a Tab Retention Device, RD1. And it should be able to slide and take the load of the Actuator when backing down. They are very effective at preventing damage or even having a Tab come of when backing down hard.
Tom
Bennett Marine
Learned something new today!
I figured that was somebody's Rube setup, but it makes sense now. Old dog can learn a new trick... Past Commodore, Peninsula Yacht Club
Lake Norman, NC
Re: Trim Tab Brace
- DanM
- Vessel Info: Carver 396
- Been thanked: 35 times
Re: Trim Tab Brace
Carver 396
SugarSand Tango
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Trim Tab Brace
When I took the boat out of the water in the fall, I removed the trim tabs to clean them up and sand blast them, as they were all gummed up with some kind of primer coating and corrosion. I am also having the chord extended on the tabs by 2.5 inches to give me more lift. I saw these brackets on the trim tabs that extend from the actuator transom mount down to the trim tab hinge. Had no idea what they were for. They were rely gummed up as well.
In preparation for splash day, I called Bennett Marine today to get a part number for new trim tab hinges and pins. I asked him (Jeff) if he knew what these brackets were for and he thought they were a lanyard to support the tabs when reversing in sport fishing. Now I had an idea what they did, but now I need to know how they work, so I googled trim tab lanyard and read an article from the Tab Man who helped someone stop losing his trim tabs with these Retention Brackets (RD001).
This then brought me to this post, where I confirmed what they were and how they are supposed to move when in proper operation. Guess what, mine do not slide, nor do they move. There is no doubt in my mind that my trim tabs where not fully extending to give me enough bow down because the retention brackets were seized and preventing them from moving downward. I can only get about 15 degrees out of them.
Now I need to decide, do I clean them up and ensure the bolt/nut allow movement, or do I just remove them because I do not sport fish or do high speed reversing.
I just thought that I would thank those who took the time to respond to this post, as I think it was of great benefit to me in figuring out what's what with my boat.
Maybe my story will help someone else and I can pay it forward. Cheers to those that helped.
Tireless
- Has thanked: 603 times
Re: Trim Tab Brace
.....but that said ( sorry )...if they were interfering with the tab down movement then I would clean up the slide mechanism and try it on the hard to make sure it works, see if you can get it working with full range, if so leave it as it serves a purpose. The important thing is you need full range for the efficient operation.Lots of boats without them not suffering any issues I think, take a wander around the yard and have a look......just my opinion of course.
Re: Trim Tab Brace
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Re: Trim Tab Brace
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Trim Tab Brace
Re: Trim Tab Brace
