spotlight
- nightsky
- Vessel Info: '94 Carver 390 cpmy
- Has thanked: 6 times
- Been thanked: 16 times
spotlight
- Been thanked: 654 times
Re: spotlight
- mjk1040
- Been thanked: 248 times
Re: spotlight
- nightsky
Re: spotlight
g36 wrote:Source of the post as a start i think i would google photos of your year and model boat and check yachtworld etc. and see where other boats like yours might have the spotlight mounted. hard to say you might get lucky with wiring already there. wiring harness probably had wires pulled and options added or not added
Thanks, good suggestion.
- nightsky
Re: spotlight
mjk1040 wrote:Source of the post Most generally it would have been mounted on the top railing over the bow pulpit and a plate would have been attached to the rail to mount the spot light on and the wiring would have come out of the rail underneath the plate. If it was on the fiberglass bridge overhang, there should be mounting holes and a wire exposed. It's possible the breaker may be for something else and the label wasn't changed. FYI, I find a good cordless LED hand held spot/flood light a lot more useful than the mounted out front spot/flood light. Mike
Thanks Mike. If I can't add a spotlight easily, that is without having to fish wires through a long, convoluted route, then I would probably go with the handheld option.
Flinty
- Vessel Info: 1995 CARVER 390 CMY, Twin CUMMINS
Re: spotlight
Nightsky, not sure if this is factory installed, however this is the location of spot light on my 390 cmy, comes with remote, however have not got it working yet.
- nightsky
Re: spotlight
- Been thanked: 490 times
Re: spotlight
Re: spotlight
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: spotlight
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Users browsing this forum: Google Adsense [Bot] and 112 guests
