Noisy Starboard transmission...rich engine
- 405driver
- Vessel Info: 1998 Carver 405 gas
- Has thanked: 37 times
- Been thanked: 6 times
Re: Noisy Starboard transmission...rich engine
- Has thanked: 78 times
- Been thanked: 1093 times
405driver wrote:Source of the postI am also including Wednesday's idle fuel pressure reading. As above, the pressure fluctuated from about 36-41 in a fairly rapid manner.
It would be interesting to see a vacuum gauge alongside that fuel pressure gauge. If the vacuum is fluctuating, the pressure will fluctuate. If the engine speed was also fluctuating, that could explain both. For testing, you can isolate them by removing and plugging the vacuum lines to the manifold and applying an appropriate vacuum ~15 inches) to the fuel pressure regulators.
- 405driver
- Has thanked: 598 times
- Been thanked: 1281 times
- 405driver
Yes... mostly about 2200 rpm lately...
- 405driver
- 405driver
I have been told if there is fuel in the oil that if you hold the dipstick straight down, the oil will drip off the dipstick...mine hangs on the dipstick normally. Thought that was interesting.
