Princess 3 burner Propane stove/oven
Flinty
Topic author - Scurvy Dog
- Vessel Info: 1995 CARVER 390 CMY, Twin CUMMINS
Problem? The stove panel next to stove is not getting power (light not lighting up when switched to "on position"? I see there is a fuse next to light, could that be the issue? not familiar with these types of fuses.
Any Ideals?
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Princess 3 burner Propane stove/oven
..Aaron
SeaDragon
Flinty
not the best picture, but the black panel below sink is labeled Propane panel, which contains an on/off switch and the small white square is labeled fuse? there is also an illumination light which lights up ( i assume) when the system is charged. will check the 12 volt panel as well. Thank You for suggestion.
Flinty
- AaHubb
..Aaron
SeaDragon
Users browsing this forum: No registered users and 361 guests
