Any winterizing/storage tips out there?
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
So my Carver is coming home to my yard so I can finish the restoration. I think I should have no problems with the engines. Really it is as easy as running pink antifreeze through them and fogging the carb and cylinders. The water and sewer system is a little different.
I already had the sewage tank diluted many times and pumped out. There is maybe 1"-2" in the tank under the toilet. Do I pump that out or dump a few gallons of pink antifreeze in there? What should I do with the lower tank? Leave it alone or pump a few gallons of pink antifreeze to it?
The water system...I think I finally found the tank! Yay! Just pop a hose off and let it drain to the hull and out the bottom? Then add pink antifreeze and pump it through the system?
Any help would be great. I am also covering it myself with tarps. It should be fun!
Thanks,
Steve
Steve
- Has thanked: 64 times
- Been thanked: 481 times
Re: Any winterizing/storage tips out there?
Drain the water tank and water heater, get enough af in so you can flush both cold and hot water systems. Run until comes out both hot and cold faucets, then drain as much as you can.
Manually pump out your shower sump, and cycle some af through it.
Same with head - not just the tank, but the intake side of the head as well.
Make sure they block your boat bow up and take the plug out, so all the water drains.
If you have ac on the boat, you'll want to suck some af through its cooling system as well.
Before you do the engines, drain all the water from the block, manifolds, etc. Don't want to dilute the af you run through. Frozen exploded blocks really are not fun to deal with!
- Seif911
- Captain
Steve
Your yard has idiots working for them
- Seif911
- Captain
Steve
- Seif911
- Captain
You mentioned the shower sump. Does the shower drain into the sewage tank? Hmmm...I only seen 1 pump out cover on the outside. I will look again. I'll peek back at this forum throughout the day for answers and maybe more questions. I found last night at I have no easy way to plug the 30 amp boat into my normal 15 amp outlets.
Steve
Late now though. Kendors in Franklin has them.
- Seif911
- Captain
I looked a few times underneath but just can't see a shower. I now suspect that I have 2 water tanks, one on each side. I have not found a access for the starboard side in the living room.
It definitely was a tad more complicated than I suspected it would be. I pumped 5 gallons of pink antifreeze in each engine, maybe 3 or 4 through the water system and 3 for the generator. Hoping that should be good.
Steve
The shower would not drain to the head-holding-tank - the smell coming up through the drain would drive you away!
- Seif911
- Captain
Steve
