1996 355 oil pressure and water temperature
Topic author
csdaman2
Vessel Info: 1996 Carver 355 Aft Cabin. Twin 454 Crusader's. Vessel Documented with the name "Justified"
Has thanked: 3 times
Been thanked: 2 times
Postby csdaman2 » April 5th, 2017, 3:25 pm
I am a new menber and recently purchased a 355 Aft Cabin. I have only had the boat out3-5 times for short runs. I am a remoldeling the boat to bring it back to a beautiful condition, the bones are very good. My question is any ideas on why the oil PSI is 80-85 on both engines? I poke around at15-1800 RPM'S. Also, My water temps are 180 and 190 degrees. Any suggestions would help. I am a little embarrassed, I haven't checked the manual, but all seems high. Csdaman2
Re: 1996 355 oil pressure and water temperature
Postby bud37 » April 5th, 2017, 3:39 pm
Are your engines closed cooled ( fresh water, heat exchanger ) or raw water cooled, also on fresh water or salt.?? If you want to rest easy get the oil pressure checked with an external mechanical gage.....does the pressure fluctuate at all when engines are hot vs cold.80-85 seems ok to me, maybe heavy weight oil in there?? Some others with the same boat combo can probably chime in.
If the engines have heat exchangers then maybe you have 180 thermostats which I would be happy with, makes the engines more efficient Imho...... :beergood:
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » April 5th, 2017, 7:41 pm
First off - as Bud said - unless you are measuring at the block with a mechanical guage, your readings will be inaccurate.
Second, assuming you have big blocks, your oil pressure when cold could be in that "neighborhood" if it's a pretty low hour boat. I would bet it's actually somewhere between 40 to 60psi cold and drops down substantially hot.
Performance oil filters as well as oil treatments (LUCAS, STP ECT) will crank it up there too.
As for the water temp, your are fine - well within the operating range.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Been thanked: 248 times
Postby mjk1040 » April 5th, 2017, 8:22 pm
Our 1998 355 AC/MY with 454 crusaders calls for and gets 40W oil (Rotella) and runs in that area psi. I'm in fresh water with open cooling and temp runs around 140 and has 143 degree thermostats in it. I'm guessing your closed cooling and would run higher in the 180 range. Mike PS=Welcome aboard the Carver craze!
Topic author
csdaman2
Postby csdaman2 » April 5th, 2017, 8:59 pm
To answer Bud 37, yes, my boat is closed cooled, low time, and is in fresh water (inland river) Thanks to all who responded, your info and opinion are greatly appreciated. I will take your advice, but all have already made me much more comfortable. I love my Carver! Glad to be a new member of the website and The Carver Club.
Csdaman2
Postby tomschauer » April 5th, 2017, 11:28 pm
My 355 with mercury closed cooling 454's idles at about 40 psi gauge and goes to about 60-70 gauge at 3200- 3500 when warm (175-180). As mentioned above it may be a gauge error, additives, oil weight or someone may have installed a high pressure oil pump somewhere along the line. I would not be to concerned unless the engines show significantly different or low pressure.
I run mobile 1 15/50.
Postby tomschauer » April 5th, 2017, 11:42 pm
Mike, I didn't realize open cooling was even an option in 1998?
Postby mjk1040 » April 6th, 2017, 3:30 pm
Tom;
That's what there. Oh no I got the rare ones', just my luck!
Postby tomschauer » April 6th, 2017, 3:44 pm
That should make it worth more!
