Leak in Presssurized fresh water System
- nashvillekat
- Vessel Info: Carver 36 1990 Aft Cabin Model Gas Engines
The water pump comes on every 3 to 5 minutes and stays on for several seconds.
The water tank was observed decreasing 1 inch every 4 to 5 hours.
The water leak is NOT in the aft part of boat like I previously thought but shows up in the forward bilge compartment (hereafter FBC).
Removed kitchen stairs and hatch to FBC.
Forward bilge pump comes on to drain several inches of water out of FBC. Not sure how often but within a day or two.
With hand pump, extracted all water out of FBC.
NO LEAKS coming thru side holes of FBC or from compartment shower and forward bathroom sink drain into.
Unscrewed plate that the forward bilge pump sits on.
Exposed hole leading into another compartment directly behind the forward bilge pump.
Observed small amount of water leaking CONTINUOUSLY thru this hole into FBC.
Undid seating around kitchen table ... no leaks anywhere.
ICE maker not connected.
No leaks in faucet fittings under kitchen sink or bathroom sink.
HELP !
Thanks for all the great replies to this post.
update dec 12
have grey pipe to kitchen cold water faucet. Will replace per suggestion it may be cracked SOMEWHERE in it's travels to the aft water pressure pump connection. QUESTIONS. What is the best routing for the new pipe ???
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Leak in Presssurized fresh water System
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Shut off all dock water and your fresh water pump. If the water continues to rise keep going.....
Maybe a through hull fitting, shaft or rudder packing, leak at freshwater tank outlet.....
Hopefully nothing that requires you to pull out for repair.
- Been thanked: 1111 times
Where is your water tank and potable water pump? Is the hot water heater back there? Do you have a washdown shower on the stern?
nashvillekat wrote:Source of the post Have isolated leak in aft part of boat. (1990 carver aft cabin model). Water rises in the aft bilge area about an inch every 4 to 5 hours. Have checked Ice box, kitchen faucets, bathroom faucets, shower faucets and toilet water hose. NO LEAKS FOUND. Any other ideas. Air conditioner ???
I am confused. In the other thread you said "Turned off aft bilge pump and no water rise after 54 hours of losing 1" in both tanks. ."
What changed?
- nashvillekat
However am now zeroing in on the leak.
facts:
pressure pump in aft compartment comes on about every 5 minutes for 15 seconds.
observed aft fresh water tank decreasing 1 inch every 3 or 4 hours.
observed water leaking into FORWARD bilge compartment
unscrewed the plate holding the forward bilge pump and revealed hole behind the pump.
OBSERVED LEAK COMING THRU THE HOLE BEHIND THE FORWARD BILGE PUMP.
The engine compartment is dry to the left and right of the engine
Unscrewed compartment behind kitchen steps.
This revealed a closed compartment and DID NOT REVEAL any plumbing.
Am considering sawing the bottom of this compartment and hope to see the plumbing underneath.
HELP HELP HELP
NashvilleKat
I'm not sure what differences they made between the 1983 model (mine) and the 1990 model (yours), but on mine the lines run from the under the berth in the aft stateroom, to the stbd side "exhaust tunnel" (under the stbd cabinetry), then TEE off near the base of the steps. One side proceeds up the stbd side to the galley and fwd head sink, the other side of the TEE crosses the engine room along the aft bulkhead, services the tub faucet, proceeds to the port side and TEEs again. One side of that TEE goes back to service the aft head sink, the other side continues up the PORT side and services the fwd shower.
You can get to or see ALL of the connections through removable hatchs. They are somewhat difficult to work on though because of the tight access... but what isn't on a boat!!
I'm wondering if all your potable water lines are grey. If so, that material was recalled many years ago due to failures. Mine would fail every couple years with another small leak. I finally changed it all over to PEX and have not had a leak since. If you have the grey stuff, I would recommend doing the same! I would get pinhole leaks or small cracks in the fittings or near the joints on the grey stuff. One was SOOOO small athat I could NOT see the leak itself, only the wetted spot on the bulkhead about a foot away. Took some time to find that even when I was looking right at the leak!
What is the "Aft bilge pipe"?? Do you mean aft bilge pump? I don't have a bilge pump in the aft bilge (probably should) but do have a shower sump there, located just forward of the berth. I do not have to unscrew anything to see it, just lift a hatch.
Then, you mention "Unscrewed compartment behind kitchen steps. ". My galley is located forward of the engines. Is yours near the aft cabin?
Some pictures might help.
