Water in forward and mid bilge
Re: Water in forward and mid bilge
I'm getting confused hearing that these might be plastic or semi-flexible rubber. The only ones I have seen are either stainless or chrome-plated metal. Are we talking about the flange where the exhaust exits the hull??
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
They are plastic. I tried inspecting for cracks but could not verify. I have a scheduled pull once weather breaks. A tech from the marina is checking what I have observed.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Observed dry areas outside the stringers. Eliminated engine and Gen pick ups.
Checked water system for pressure holding by observing pump action. No cycling of pump.
Emptied water tank and heat water tank. Continued to get water in bilge.
Measured cycle of bilge pump at 30 minute cycle. Knew I was dealing with alot of water.
Run forward bilge until it ended pumping water. Bailed out bilge to observe ac pickup. No water coming from pick-up. Saw water running into bilge from the mid bilge.
Performed the same process for mid bilge. No water coming from the three thruhulls for transducers and speed temp sensors. Observed water coming into bilge from aft area.
Double checked shaft log area. Dry!
Showder sump dry.
Rudder logs dry
Found water last place I looked.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- mjk1040
- Been thanked: 248 times
Hopefully it just needs resealed.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
But thats just me...if I didn't do that, it would be in the back of my head literally all season....
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Were you ever able to tell exactly where it was leaking?
Lyndon670 wrote:Source of the post....I would talk nicely to the travel lift operator ....Don't even block the boat, just keep it in the sling. Fix the repair and slide her back in....
As a certified Travel Lift operator, I can tell you that this is an unsafe practice, and that no operator should allow it for the sake of the marina, the boat owner, and himself. For your own safety, never get anywhere near a boat until it is sitting on blocks and properly supported otherwise you're putting way too much faith in a pair of slings that you don't know whether the marina has been diligently getting stress tested ($$$). The way to a quick haul out and launch is to set the boat on a pair of temporary block piles, set a couple of jack stands at the aft corners and leave the slings on to take most of the weight, but the vessel must be sitting on blocks to comply with safety codes.I agree though, it would drive me nuts all summer if I didn't get it fixed.
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
