Rebuilding Sherwood E35 raw pumps
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
One other thing.. the pumps seem to work great pump plenty, do not leak, and last year when I replaced impellers bearing felt smooth. Should I even mess with it? Thanks!
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Rebuilding Sherwood E35 raw pumps
- MakinTime
- Has thanked: 78 times
- Been thanked: 1093 times
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
You will need a press to do the job. You should take some measure so you can orient the pulley back to its proper position so belt alignment is correct. Having said all that, I wouldn't do it until it gives me a reason to. Impeller change - yes but a major is a judgment call.
- Has thanked: 598 times
- Been thanked: 1281 times
I also would like to see more about the crank pumps as I was checking out my installation the other day and merc only has one bracket holding the pump in place , thus allowing some mis alignment of the pump pulley which I believe would put undue pressure on the pump bearing.... ( not good )....what say you folk???? Where is a good place get these?........
- mjk1040
- Been thanked: 246 times
- MakinTime
Users browsing this forum: Google Adsense [Bot] and 33 guests
