Carver 355 rear platform access
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Carver 355 rear platform access
Have never taken them out through the cabin. Took one look the first time and opted to go through the swim platform from then on...much easier IMO.
Elliott
Topic author - Scurvy Dog
- Vessel Info: 355 aft. 1998
registered boat name, Point Zero - Location: From Montreal , Canada, Boat in 1000 islands Ontario canada
- Has thanked: 4 times
- Been thanked: 2 times
How do these tanks get pinholes, and, what about the main tanks, or are your comments just relegated to the auxiliary tank?
After reading the post prior to yours I had decided that I would not bother with trying the tank, as once there is a problem I would have to go further.,and the smell is a warning of a hazard.
Also,when you state,"take them about by the swim platform" I assume you mean cutting the back of the boat open.
Point Zero
See our band, Switchback,
Light my fire 2012, finale,with Robbie Krieger of THE DOORS
http://www.youtube.com/watch?v=xcQq7-YWnDE company
Ever see a stern thruster on one of these boats?
Elliott wrote:Source of the post.....I can not imagine how a company like Carver would make a boat with a tank problem.....
I doubt it was anything Carver foresaw happening. Could have been a poor or low quality batch of aluminum the tank manufacturer used when they produced a quantity for Carver, or the way the tanks were installed, hard to say. My theory is that for the most part, people rarely use these tanks. I suspect they often sit pretty empty and collect a lot of water from condensation, the effects of ethanol, etc. This would definitely contribute to bottom corrosion as that's where the water would sit. This auxiliary/saddle tank issue is actually pretty common with other brands too in my experience, not necessarily a "Carver" specific issue.
I've actually never had to replace any main tanks on a Carver but I can comfortably say that's not the case with some other brands, and they've been a mix of bottom pinhole leaks or bad welds. Whether that's a coincidence or not I don't know but I do know we've had a couple of threads here re main tank replacement on Mariners if I recall.
Elliott
Maybe you know the answer to the following.
At the bottom of the rear steps, on the platform, there is a square section as wide as the steps, about 16x16 that appears as if the platform was cutout. The previous owner may have had a small issue and serviced it, but during my first summer last year 3 sides of this square seemed to have moisture coming out,. No softness at all.
I thought I would have to open it up and re glass the section of the deck, but, in my discoveries last weekend of the inside of the platform, I examined the area very carefully and there was no cutout on the inside or breakthrough whatsoever. It was just solid fibreglass.
So , I was thinking of grinding out the 3 sides the square that show the outline, cleaning it up and re sealing it. But I have no idea what to use. In my mind a white 5200 paste would do it for me. Any Ideas,
Point Zero
- Been thanked: 646 times
g36 wrote:Source of the post Hi elliot I can suggest while you are concerning yourself with the rear platform is to remove the oem dock box and investigate each mounting hole for rot and repair and rebed. This is a known issue with 355 405 families.....
+1
Elliott wrote:Source of the post....At the bottom of the rear steps, on the platform, there is a square section as wide as the steps, about 16x16 that appears as if the platform was cutout. The previous owner may have had a small issue and serviced it, but during my first summer last year 3 sides of this square seemed to have moisture coming out,. No softness at all.
I thought I would have to open it up and re glass the section of the deck, but, in my discoveries last weekend of the inside of the platform, I examined the area very carefully and there was no cutout on the inside or breakthrough whatsoever. It was just solid fibreglass....
Sounds like a poor glass and possibly core repair to me. In such a case, it's not necessary to cut all the way through. One would simply cut the top layer of glass, then remove the core while leaving the bottom layer of glass intact. This gives you a glassed in surface to work with and lay your new core into.
Elliott wrote:Source of the post.....I was thinking of grinding out the 3 sides the square that show the outline, cleaning it up and re sealing it. But I have no idea what to use. In my mind a white 5200 paste would do it for me. Any Ideas,
Take a sounding, you may have delamination there, and trapped moisture. Do a core sample to check it's condition of the areas in question and if it reveals an issue, remove the questionable section and do a proper fiberglass repair. Don't use caulking or you'll be starting another thread about it again in the near future. Caulking doesn't last forever.
Elliott
Point Zero
