Aft deck plastic panels
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
- dsouder
- Vessel Info: 1994 Carver 300 Aft Cabin
- Contact:
Any suggestions on where I might be able to get these?
Ondercin
- Vessel Info: 1988 carver 3607 AFT
Penetanguishene - Has thanked: 2 times
- Been thanked: 3 times
Re: Aft deck plastic panels
I've sent off a few emails looking for a fabricator to make them for our 1988 3607 aft cabin, but I'm also considering doing it myself...
I've just started researching companies, so if I don't anyone commenting to your post, I'll let you know how I make out.
I've spoken to a very bright individual this morning and he recommended UMHW plastic.
Penetanguishene
- dsouder
- Contact:
Thank you for this info. I have considered doing them myself as well with standard white plexiglass or similar materials. At a little bit of a loss for the corner piece.
Ondercin
If I get a chance I'm going to take it to the boat and fasten it to the stanchions for the week.. I might have to apply a resin to keep the curve.. then I was going to use that as my mold or perhaps I'll wrap it in fibreglass...
I'll see how this weekend goes.. busy family time so I'm not sure if I'll get any boat time
Penetanguishene
- Been thanked: 646 times
- dsouder
- Contact:
I have contacted carver/marquis and this was their reply:
Unfortunately we can no longer make the panels or the corners, the panels were made from ¼” acrylic (plexiglass) you may want to contact a local cabinet shop as they often use that type of materials, they would have to custom make them. The corners were made from a aluminum painted extrusion, that extrusion is no longer made as the company we used to buy the extrusion from threw away their press molds to make it. All we would have is the plastic rivets or the spacers if you had spacers on your panels to attach to the rails.
The reply was sent from a btemple@marquisyachts. I'm assuming this may be the Brett you are refering to.
Ondercin
The 90 degree bend formed okay, but we did soak it for a minute in the water and I pressed it into place... The boss looked it over for a few minutes then asked to go for a walk so she could look at a few carvers across the marina that have the solid panels.
In short she choose not to go for the panels but talked to the canvas guy and wants a canvas "dodger" with some clear panels for being able to look down close to the water to see the children..
After attempting this I think the 1/4 ply would work, but I would have took a quick look for something else just before fibreglassing as it might be too thick. It could be done but perhaps something more plyable that fibreglass could adhere to.
Penetanguishene
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
Anne Bonny
- Vessel Info: 1995 355 Aft Cabin
For the plexiglass replacement, we went to a local glass company, specifically in CT, Middletown Plate Glass. It is a special order piece which ran about $380.00 with left over scrap. The starboard side is a tab bit longer than 4'.... so an 8' panel was needed.
For the rivets and spacers. We found a company in CA, Product Components Corporation, www.product-components.com . For $50 plus shipping we ordered 50 of each... rivet # B16015 and spacer # C38410. Only thing is the spacers are not concaved on one end which one may decide to leave asis or carefully run the end against a drill press. PCC were quick in their response and highly recommend them and their services. Yes, you can order fewer than 50.
1995 355 Aft
Mystic, CT
greghotz
- Vessel Info: 1998 Carver 405
- Been thanked: 2 times
I have the same issue with my 405. Try Total Plastic Inc. They have several shops, one in PA, one in Baltimore and several in the midwest. They will cut panels to size and carry the t same type of material as Carver used long ago. The colors may not match if your just replacing one part due to sun fade. I'm looking for the plastic standoffs used to mount them to the rails.
Return to “Boat Parts For Sale”
