Shore water
- travellersrest
- Vessel Info: I own a 1999 530 Voyager with 450 Cummins 6CTA8.3. We are the second owners, and have had her 14 years.
Shore water
Thanks in advance for your help.
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Shore water
http://www.defender.com/product3.jsp?name=shurflo-wall-mount-city-water-connection&path=-1|51|2234261|2234266&id=2410648
or
http://www.defender.com/product3.jsp?name=ambassador-stainless-steel-water-inlet&path=-1|51|2234222|2234225&id=2122921
The first has a built in regulator/check valve, the second does not. Even if you have the first, if it came from factory with the second and was changed by a previous owner, it may still have the separate regulator in the boat that may be at fault.
Also note that some vessels have outlet fittings for a raw water system but that would be the opposite end of the hose you'd be hooking up just like at a tap unless someone messed up.
Has it ever worked before? Do you winterize where you are? It's a common failure when not done right.
- travellersrest
Re: Shore water
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Shore water
travellersrest wrote:Source of the post The shore water system worked just fine up until about two years ago. Yes I do winterize the water system each year with the pink stuff (-50degree). I flush the entire water system with the pink stuff.
You may just have another check valve between the shore hook up and where it connects to the main system and it is stuck.....I installed some in my last boat and they were plastic and looked just like a regular fitting, maybe check that line and with the pressure on, tap all the fittings and maybe you can unstick it.......just a shot in the dark here considering you have had this boat for a while....
Just had a look at your schematic for the water system on your boat.....
.http://www.carveryachts.com/media/3892/ ... ual_99.pdf
I believe you can cut the inlet regulator out ,just for a test mind you,by hooking up shore water to your fresh water wash down tap.....now this would just test that section to the regulator, don't open wide and see if your system works, don't leave it like that, it is just to test !!......if it does then you will know where to keep looking.... the only factory check valve I could find was at the hot water tank........
- Been thanked: 601 times
Re: Shore water
Re: Shore water
Did you push the pink stuff through the dockside water inlet? If you didn't and there's a valve/regulator there or in that line, it'll be toast. It's a common oversight when winterizing. You need to either force pink through it or air to clear water out of the regulator and that section of line. Trying to do it from the other end while you're doing the rest of the system with your on-board pump won't work.
Re: Shore water
You'd need to rig something up because that would require a hose with two female ends.
tomschauer wrote:Source of the post Maybe just disconnect the new shore water inlet and turn on the pump. Water should flow from the pipe that connects to the inlet. If not, definitely another check or shut off valve in the line.
+1
If that doesn't work, you need to get eyes on the line from the inlet all the way to where it connects to the on-board system which will likely be the lines leading to the closest fixture like fresh water washdown, transom shower lines or lines to a cockpit sink or ice maker.
Re: Shore water
Re: Shore water
Re: Shore water
tomschauer wrote:Source of the post You could hook up to a wash down using a washing machine hose, but I do believe you would pressurize your storage tank. That could make a big mess.
No, it wouldn't be any different than a working dockside water inlet (all hooks up to the same circuit/plumbing). The tank won't fill up because of the check valve in your fresh water pump won't let water past it back to the tank. If your tank does fill up, then you have a faulty pump but if that was the case, your pump would always cycle on and off as the system would lose pressure from the water draining back into the tank again.
