Rudder position gauge
dsolo
Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll
Has thanked: 68 times
Been thanked: 25 times
Postby dsolo » May 13th, 2017, 6:56 am
I measured the number of turns the steering wheel turns and position the wheel at midpoint. The rudder position gauge reads off to the starboard at 2 o'clock. The autopilot's rudder position is just off 12 o'clock, almost perfect to the steering wheel position. Can someone tell me how to calibrate the gauge?
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Been thanked: 491 times
Re: Rudder position gauge
Postby waybomb » May 13th, 2017, 7:32 am
There was a turnbuckle at the sender connected to the rudder arm.
Center the rudder then center the sender.
Maybe yours is the same.
Postby Viper » May 13th, 2017, 8:16 am
You don't calibrate the gauge, you adjust the position of the sender relative to the rudder's position by adjusting the length of the sender's connecting rod with the turnbuckle. You'll likely have two rudder position senders at the rudders; one for the gauge and one for the autopilot. The autopilot one should be stamped with the same brand as the autopilot. Start off as Fred describes above, then make subtle changes until the needle is centered. Having someone at the helm while you make the adjustments makes this job a lot easier. You must ensure the rudders are actually in the center position before you start this. You can tell by the position or the connecting arms. Providing all the hardware; gauge, sender and wiring are okay, you should get a true reading once it's set up properly.
Been thanked: 470 times
Postby RGrew176 » May 14th, 2017, 5:50 am
Boy, I wish my Carver came with a rudder gauge. The Chris Craft I almost bought before I found the Carver did have a rudder gauge.
Postby Viper » May 14th, 2017, 8:50 am
It's a pretty easy install Rick or get one of these. Not quite the same but a lot easier install.
https://www.amazon.com/Davis-385-Rudder-Position-Indicator/dp/B005GT6EZ0
Postby Midnightsun » May 14th, 2017, 9:40 am
Viper wrote:Source of the post It's a pretty easy install Rick or get one of these. Not quite the same but a lot easier install.
I had one like that and replaced it only to have it also go bad. Not exactly the best thing out there IMHO.
I replaced mine last year simply for aesthetic purposes with this unit. They are rather cheap as can be seen here. They come in black or white and are suitable for 12 or 24v systems. http://www.ebay.com/itm/KUS-Boat-Rudder ... cc&vxp=mtr
Postby Viper » May 14th, 2017, 2:22 pm
Rick, I recall you had installed some new electronics or a plotter. Depending on what you got, you may be able to tie a rudder position sensor to it and get a reading on the display.
Shipfaced1
Vessel Info: 1982 Carver 3007
Has thanked: 19 times
Been thanked: 6 times
Postby Shipfaced1 » May 16th, 2017, 8:08 am
Rick, my '82 has the gauge in both the lower and upper helm. My owner's manual mentions them a few times as well so I figured it a standard option? I'm surprised yours doesn't.
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » May 19th, 2017, 5:45 pm
Thanks all for the instructions. I plan to do the job next week.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » June 12th, 2017, 10:51 pm
Rudder position adjustment went as Viper described. Had to adjust the position of the sensor's connection rod by loosening the set screw and repositioning it on the stud. This allowed the turnbuckle to be repositioned for more thread for adjustment. Rudder meter reading true position now.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Users browsing this forum: km1125, KyleR and 42 guests
