Installing Flooring in Carver Mariner
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Re: Installing Flooring in Carver Mariner
Postby SanJuanDreamer » April 24th, 2017, 3:37 pm
Bryon857, the floor space just in front of the dinette table, did you see anything that might explain why the floor moves a little?
Bryon857
Vessel Info: 2002 carver 350 mariner
Has thanked: 2 times
Been thanked: 13 times
Postby Bryon857 » April 24th, 2017, 4:49 pm
This may be what you are asking. There is a 3/4 inch plywood across the middle of the boat. It has some aluminum crossmembers for support. Mine has a little give also, added the 1/2 engineered wood on top of it, seems to help some.
SanJuanDreamer
Postby SanJuanDreamer » April 24th, 2017, 10:28 pm
Ah, good idea..
Bryon857
Postby Bryon857 » April 26th, 2017, 9:45 pm
Still working, out of flooring trying to order some more. Use 3 boxes about a 100 sq ft., not a lot of waste.
Randymccann
Vessel Info: 1986 32ft carver mariner
Has thanked: 6 times
Postby Randymccann » April 28th, 2017, 5:07 am
Just got done having mine done was vynl planking that looks like wood. Had to be glued down.
prowler1k
Vessel Info: 2002 Carver 396 Aft Cabin
Postby prowler1k » April 29th, 2017, 10:36 pm
Looks great and gives us an idea of what is in store! Recently purchased a 2002 396 and going to use the snap on laminate flooring from Lowes. Still exploring details...what are your plans for the stairs?
Thanks for sharing your experience!
Bryon857
Postby Bryon857 » May 12th, 2017, 12:20 pm
Still at it
cpoint
Has thanked: 208 times
Been thanked: 31 times
Postby cpoint » May 13th, 2017, 9:58 pm
looks great, you done a fantastic job. i am nearly done with mine....
SanJuanDreamer
Postby SanJuanDreamer » May 13th, 2017, 11:41 pm
Wow...just amazing!!!! Ok, you can do mine next?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » May 15th, 2017, 12:06 pm
Awsome!!! Great shots.
