Muskrats...fresh water boaters take note
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Re: Muskrats...fresh water boaters take note
Also, does anyone have suggestions on blocking water at the hull so this can be done in the water? Is there a tape or plastic sheet that would work? I just paid for a hull out to fix the leak on the starboard exhaust flange, it was leaking at the hull.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Preferred
- Vessel Info: 455 Carver 1998
- Has thanked: 6 times
- Been thanked: 2 times
dsolo wrote:Source of the post
On mine I have a flange sticking out, so it was easy to wrap some plastic over it and just tape it to the flange.
On yours, you could get a wheel barrow tube. Cut it in half, closer to the valve. Seal both ends closed (5200 and a good tie-wrap would probably do the trick. Stick the "long" end into the exhaust with the valve end sticking out. Use a bike pump to fill the tube until it makes a seal around the edges.
- dsolo
454 EFI Crusaders
Thanks Lyndon for the post. I have a SS mush I will be installing.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
