bilge hose won't co-operate
- Preferred
- Vessel Info: 455 Carver 1998
- Has thanked: 6 times
- Been thanked: 2 times
- mjk1040
- Been thanked: 248 times
Re: bilge hose won't co-operate
- Has thanked: 603 times
Preferred wrote:Source of the post replacing my forward bilge hose, due to cracking at the pump. the hose goes through stringers under the forward head.It is being stubborn, thinking of using a smaller hose and feeding it through the existing hose, and installing couplers at the end to fit the pump and through hull? has any one solved this issue?
You may be able to get back to the same original flow if when or if you change the hose size , by going to a larger bilge pump....check the various flow rates of the pumps with various hose sizes. Remember even if you only change the hose to smaller for 1 inch that means the pump sees that size for the entire length of the hose and change the flow rate accordingly......hope this helps.
edit ... to add I will say that the best solution would be to remove and replace the hose properly as has been suggested .
- Preferred
the hose 12-15 ft ???goes through 3 stringers that are rough cut fiberglass all are 90 degree turns. not a very well thought out design. under the forward head, and under the generator. A magician couldn't hide it better.
thanks for the reply's
Don
- Preferred
I forgot to mention I have a muskrat story to share, with pictures. On inspecting the only way this hose could have been compromised is by a muskrat chewing on the hose. It was in the fall and wasn't in the engine room long enough to do other damage that I can find. The insurance company was notified immediately just in case there is damage not yet discovered. I have installed muskrat preventers on the exhausts. I will take pictures and share the story next week.
thanks
Don
- mjk1040
Not very ideal indeed!!! Is this corrugated hose? Every foot you run through on that add resistance and lowers pump capacity. Add turns and it drops again. Would be interesting to actually put water in the bilge and see what the actual pumping capacity is.
Is there any way to re-route to make it shorter and put in another through-hull that would be closer to the pump?
